Ga door naar hoofdinhoud
Sceptre X9 Komodo VII Speakers Replacement
Wat je nodig hebt
  1. Sceptre X9 Komodo VII Speakers Replacement, Stand: stap 1, afbeelding 1 van 1
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Speakers Replacement: stap 2, afbeelding 1 van 1
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Speakers Replacement, Board Cover: stap 3, afbeelding 1 van 1
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Speakers Replacement: stap 4, afbeelding 1 van 3 Sceptre X9 Komodo VII Speakers Replacement: stap 4, afbeelding 2 van 3 Sceptre X9 Komodo VII Speakers Replacement: stap 4, afbeelding 3 van 3
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Speakers Replacement: stap 5, afbeelding 1 van 2 Sceptre X9 Komodo VII Speakers Replacement: stap 5, afbeelding 2 van 2
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
  6. Sceptre X9 Komodo VII Speakers Replacement, Speakers: stap 6, afbeelding 1 van 1
    • Disconnect the two connectors to the speakers by gently pulling on the hard plastic straight up.
  7. Sceptre X9 Komodo VII Speakers Replacement: stap 7, afbeelding 1 van 1
    • Carefully peel the tape from the board.
  8. Sceptre X9 Komodo VII Speakers Replacement: stap 8, afbeelding 1 van 1
    • Flip the monitor so the screen is facing you.
    • Using Phillips #2 screwdriver remove the four 6.25 mm screws securing the speakers:
  9. Sceptre X9 Komodo VII Speakers Replacement: stap 9, afbeelding 1 van 1
    • Carefully lift the speakers up.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Xenia Leon Rodriguez
37 Reputatie
1 Handleiding geschreven
Cal Poly, Team 16-56, Forte Fall 2012 Lid van Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
5 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 397
