Ga door naar hoofdinhoud
Sceptre X9 Komodo VII Board Cover Replacement
Wat je nodig hebt
  1. Sceptre X9 Komodo VII Board Cover Replacement, Stand: stap 1, afbeelding 1 van 1
    • Place the monitor face down.
    • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the stand by pulling it out.
  2. Sceptre X9 Komodo VII Board Cover Replacement: stap 2, afbeelding 1 van 1
    • Remove two 11.5mm screws with a #2 Phillips screwdriver.
    • Remove the plastic bar.
  3. Sceptre X9 Komodo VII Board Cover Replacement, Board Cover: stap 3, afbeelding 1 van 1
    • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  4. Sceptre X9 Komodo VII Board Cover Replacement: stap 4, afbeelding 1 van 3 Sceptre X9 Komodo VII Board Cover Replacement: stap 4, afbeelding 2 van 3 Sceptre X9 Komodo VII Board Cover Replacement: stap 4, afbeelding 3 van 3
    • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
    • Once all the clips have been released, remove the cover by pulling it up.
  5. Sceptre X9 Komodo VII Board Cover Replacement: stap 5, afbeelding 1 van 2 Sceptre X9 Komodo VII Board Cover Replacement: stap 5, afbeelding 2 van 2
    • Using the #2 Phillips screwdriver, remove the one 6mm screw.
    • Unplug the indicated cable by pulling on the base.
    • Slide the cover toward the top of the monitor.
    • Remove the cover.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ted Hsueh
170 Reputatie
3 handleidingen geschreven
Cal Poly, Team 16-56, Forte Fall 2012 Lid van Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
5 Leden
13 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 457
