Ga door naar hoofdinhoud
Sanyo-PM 8200 Motherboard Replacement
Wat je nodig hebt
  1. Sanyo-PM 8200 Motherboard Replacement, Power Off Phone: stap 1, afbeelding 1 van 1
    • Power down the phone by holding down the red "end" button.
  2. Sanyo-PM 8200 Motherboard Replacement, Remove Old Battery: stap 2, afbeelding 1 van 1
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  3. Sanyo-PM 8200 Motherboard Replacement, Back Casing: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
  4. Sanyo-PM 8200 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Unscrew all four, 5mm Tri-Wing screws.
  5. Sanyo-PM 8200 Motherboard Replacement: stap 5, afbeelding 1 van 2 Sanyo-PM 8200 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Pry the back casing off the device using a spudger. Work your way along the edges to completely separate the back casing from the device.
    • This step may require extra force. But too much force could break the back casing.
    • Remove the headphone jack cover when separating the back casing. The headphone jack is located on the opposite side of the antenna.
  6. Sanyo-PM 8200 Motherboard Replacement, Lift the Motherboard: stap 6, afbeelding 1 van 1
    • Gently lift up the motherboard. The keypad should now be exposed.
  7. Sanyo-PM 8200 Motherboard Replacement, Disconnect the Flex Ribbon: stap 7, afbeelding 1 van 1
    Koop
    • Using tweezers, pull on the silver flex ribbon to disconnect it from the motherboard.
  8. Sanyo-PM 8200 Motherboard Replacement, Remove the Motherboard: stap 8, afbeelding 1 van 1
    • Remove the motherboard from the back of the phone.
Conclusie
Michaella
101 Reputatie
1 Handleiding geschreven
USF Tampa, Team 1-6, Leahy Fall 2014 Lid van USF Tampa, Team 1-6, Leahy Fall 2014
USFT-LEAHY-F14S1G6
6 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 385
