Wat je nodig hebt
Push and hold the button on the back toward the direction of the arrow to unlock the battery.
Lift and remove the battery from the back of the phone.
Use a push pin or tweezers to remove the neoprene screw-cover located on the upper, left corner of the back casing.
Gently lift up the motherboard. The keypad should now be exposed.
Using tweezers, pull on the silver flex ribbon to disconnect it from the motherboard.
