Ga door naar hoofdinhoud
Sanyo VPC-T850 LCD Display Replacement
Wat je nodig hebt
  1. Sanyo VPC-T850 LCD Display Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 LCD Display Replacement: stap 2, afbeelding 1 van 1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 LCD Display Replacement: stap 3, afbeelding 1 van 1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 LCD Display Replacement: stap 4, afbeelding 1 van 1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
  5. Sanyo VPC-T850 LCD Display Replacement, Outer Casing: stap 5, afbeelding 1 van 3 Sanyo VPC-T850 LCD Display Replacement, Outer Casing: stap 5, afbeelding 2 van 3 Sanyo VPC-T850 LCD Display Replacement, Outer Casing: stap 5, afbeelding 3 van 3
    • Using your Phillips #000 Screwdriver, remove the eight screws located around the sides and bottom of the camera.
    • Be sure to keep track of the side each screw comes from, as they come in different lengths.
  6. Sanyo VPC-T850 LCD Display Replacement: stap 6, afbeelding 1 van 2 Sanyo VPC-T850 LCD Display Replacement: stap 6, afbeelding 2 van 2
    • Orient the camera so the display is facing up.
    • Gently pull off the rear panel surrounding the display.
    • There are still three green wires connecting the panel to the rest of the camera.
    • Use your prying tool if you have difficulties removing the panel by hand.
  7. Sanyo VPC-T850 LCD Display Replacement: stap 7, afbeelding 1 van 1
    • Remove the eight black screws connecting the keypad circuit board to the rear panel.
  8. Sanyo VPC-T850 LCD Display Replacement: stap 8, afbeelding 1 van 2 Sanyo VPC-T850 LCD Display Replacement: stap 8, afbeelding 2 van 2
    • With a plastic opening tool, gently remove the chrome framing on the left and right sides of the camera.
  9. Sanyo VPC-T850 LCD Display Replacement: stap 9, afbeelding 1 van 1
    • Flip the camera over so the lens is facing up.
    • Gently lift up the front panel to remove it from the rest of the camera.
    • Use your plastic opening tool if you have difficulties removing the panel by hand.
  10. Sanyo VPC-T850 LCD Display Replacement, LCD Display: stap 10, afbeelding 1 van 1
    • Flip the device over to where the display is located.
    • Using your plastic opening tool, lift the display out of its metal housing.
  11. Sanyo VPC-T850 LCD Display Replacement: stap 11, afbeelding 1 van 1
    • Locate the orange ribbon connecting the display to the camera.
    • Using your plastic opening tool, gently lift the black bar holding the orange ribbon to the camera.
  12. Sanyo VPC-T850 LCD Display Replacement: stap 12, afbeelding 1 van 1
    • With two fingers held firmly on the display, gently pull the orange ribbon out of the camera.
    • Pull slowly to avoid severing the orange ribbon from the display.
Conclusie
Devin Farnsworth
101 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 354
