Ga door naar hoofdinhoud
Sanyo VPC-T850 Battery Replacement
Wat je nodig hebt
  1. Sanyo VPC-T850 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the camera is powered off by pressing and holding the small, square button embedded in the top rim of the camera.
  2. Sanyo VPC-T850 Battery Replacement: stap 2, afbeelding 1 van 1
    • Locate the hatch found on the bottom of the camera.
    • Open the hatch by gripping the small notch and sliding it outwards.
  3. Sanyo VPC-T850 Battery Replacement: stap 3, afbeelding 1 van 1
    • Push the small, plastic arm out of the way to free the battery.
    • The battery is spring loaded and will pop out slightly when the arm is moved.
  4. Sanyo VPC-T850 Battery Replacement: stap 4, afbeelding 1 van 1
    • Pull the battery out of the camera and close the hatch.
    • To reinsert, there is a triangle on the battery indicating which direction to slide it in.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
James Robinson
459 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-5, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 23
Altijd: 888
