Ga door naar hoofdinhoud
Sanyo VPC S1275 LCD Screen Replacement
Wat je nodig hebt
  1. Sanyo VPC S1275 LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place your thumb on the right side of the camera over the battery door.
    • Slide the battery door to the right until the door lifts up.
  2. Sanyo VPC S1275 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove and recycle old batteries.
  3. Sanyo VPC S1275 LCD Screen Replacement, Case: stap 3, afbeelding 1 van 3 Sanyo VPC S1275 LCD Screen Replacement, Case: stap 3, afbeelding 2 van 3 Sanyo VPC S1275 LCD Screen Replacement, Case: stap 3, afbeelding 3 van 3
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
  4. Sanyo VPC S1275 LCD Screen Replacement: stap 4, afbeelding 1 van 2 Sanyo VPC S1275 LCD Screen Replacement: stap 4, afbeelding 2 van 2
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
  5. Sanyo VPC S1275 LCD Screen Replacement: stap 5, afbeelding 1 van 3 Sanyo VPC S1275 LCD Screen Replacement: stap 5, afbeelding 2 van 3 Sanyo VPC S1275 LCD Screen Replacement: stap 5, afbeelding 3 van 3
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  6. Sanyo VPC S1275 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
  7. Sanyo VPC S1275 LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
  8. Sanyo VPC S1275 LCD Screen Replacement, LCD Screen: stap 8, afbeelding 1 van 2 Sanyo VPC S1275 LCD Screen Replacement, LCD Screen: stap 8, afbeelding 2 van 2
    • Using the spudger, carefully lift up the LCD screen, making sure to keep the ribbon cable intact.
    • Place the LCD screen on a non-abrasive surface.
  9. Sanyo VPC S1275 LCD Screen Replacement: stap 9, afbeelding 1 van 1
    • Using the spudger lift the black flap up to release the ribbon cable.
    • The LCD screen will now be completely detached from the camera.
Conclusie
Evan Perez
19 Reputatie
2 handleidingen geschreven
Cal Poly, Team 24-24, Regan Spring 2010 Lid van Cal Poly, Team 24-24, Regan Spring 2010
CPSU-REGAN-S10S24G24
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 3,094
