Inleiding
In order to install the speaker for the Sanyo SCP-8100, you will need to unscrew and pry the back panel off of the phone. The speaker is located on the back panel itself and easy to replace.
  • Note: In order to pull out the plug on the back of the phone that is hiding one of the screw, you will need to use a push pin. A spudger or opening tool is too thick to take it out.
  1. Push and hold the button on the back toward the direction of the arrow to unlock the battery. Lift and remove the battery from the back of the phone. Lift and remove the battery from the back of the phone.
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  2. Using a push pin, pull out the plug on the back, located under the antenna. You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  3. Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  5. Use a plastic opening tool to pry the back panel along the edges. You may need to apply some force when prying.
    • Use a plastic opening tool to pry the back panel along the edges.
      • You may need to apply some force when prying.
  6. While removing the back panel, take out the rubber cover on each side. While removing the back panel, take out the rubber cover on each side. While removing the back panel, take out the rubber cover on each side.
    • While removing the back panel, take out the rubber cover on each side.
  7. Pull the connector at the top of the back panel out. You may need to use some force when pulling.
    • Pull the connector at the top of the back panel out.
      • You may need to use some force when pulling.
      • It may still be connected to the phone instead of the back panel.
  8. Use the opening tool to lift the speaker out from the right side. Use the opening tool to lift the speaker out from the right side.
    • Use the opening tool to lift the speaker out from the right side.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Paul Truong
1 Reputatie
2 handleidingen geschreven
Cal Poly, Team 10-41, Amido Spring 2013 Lid van Cal Poly, Team 10-41, Amido Spring 2013
CPSU-AMIDO-S13S10G41
4 Leden
12 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 276
