Ga door naar hoofdinhoud
Sanyo SCP-8100 Keypad Replacement
Wat je nodig hebt
  1. Sanyo SCP-8100 Keypad Replacement, Battery: stap 1, afbeelding 1 van 3 Sanyo SCP-8100 Keypad Replacement, Battery: stap 1, afbeelding 2 van 3 Sanyo SCP-8100 Keypad Replacement, Battery: stap 1, afbeelding 3 van 3
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  2. Sanyo SCP-8100 Keypad Replacement, Back Panel: stap 2, afbeelding 1 van 2 Sanyo SCP-8100 Keypad Replacement, Back Panel: stap 2, afbeelding 2 van 2
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  3. Sanyo SCP-8100 Keypad Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
  4. Sanyo SCP-8100 Keypad Replacement: stap 4, afbeelding 1 van 2 Sanyo SCP-8100 Keypad Replacement: stap 4, afbeelding 2 van 2
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
  5. Sanyo SCP-8100 Keypad Replacement: stap 5, afbeelding 1 van 3 Sanyo SCP-8100 Keypad Replacement: stap 5, afbeelding 2 van 3 Sanyo SCP-8100 Keypad Replacement: stap 5, afbeelding 3 van 3
    • While removing the back panel, take out the rubber cover on each side.
  6. Sanyo SCP-8100 Keypad Replacement, Keypad: stap 6, afbeelding 1 van 2 Sanyo SCP-8100 Keypad Replacement, Keypad: stap 6, afbeelding 2 van 2
    • Pull the volume and camera buttons off from the side of the phone.
  7. Sanyo SCP-8100 Keypad Replacement: stap 7, afbeelding 1 van 2 Sanyo SCP-8100 Keypad Replacement: stap 7, afbeelding 2 van 2
    • Pull the gray frame covering the charging port from the bottom of the phone.
  8. Sanyo SCP-8100 Keypad Replacement: stap 8, afbeelding 1 van 2 Sanyo SCP-8100 Keypad Replacement: stap 8, afbeelding 2 van 2
    • Use the opening tool to lift the motherboard up from the phone.
    • Be careful and pry the motherboard off slowly. The motherboard will be attached to the phone at the top by a metal ribbon.
  9. Sanyo SCP-8100 Keypad Replacement: stap 9, afbeelding 1 van 3 Sanyo SCP-8100 Keypad Replacement: stap 9, afbeelding 2 van 3 Sanyo SCP-8100 Keypad Replacement: stap 9, afbeelding 3 van 3
    • Flip open the phone, exposing the keypad.
    • Use the opening tool to push the buttons from the bottom to lift the rubber keypad up.
    • Pull the keypad out of the phone.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Irenz Afable
57 Reputatie
3 handleidingen geschreven
Cal Poly, Team 10-41, Amido Spring 2013 Lid van Cal Poly, Team 10-41, Amido Spring 2013
CPSU-AMIDO-S13S10G41
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 384
