Ga door naar hoofdinhoud
Sanyo Katana Screen Replacement
Wat je nodig hebt
  1. Sanyo Katana Screen Replacement, Screen Protector: stap 1, afbeelding 1 van 2 Sanyo Katana Screen Replacement, Screen Protector: stap 1, afbeelding 2 van 2
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Screen Replacement: stap 2, afbeelding 1 van 2 Sanyo Katana Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Screen Replacement: stap 3, afbeelding 1 van 2 Sanyo Katana Screen Replacement: stap 3, afbeelding 2 van 2
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
  4. Sanyo Katana Screen Replacement, Front Case: stap 4, afbeelding 1 van 3 Sanyo Katana Screen Replacement, Front Case: stap 4, afbeelding 2 van 3 Sanyo Katana Screen Replacement, Front Case: stap 4, afbeelding 3 van 3
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
  5. Sanyo Katana Screen Replacement, Screen: stap 5, afbeelding 1 van 2 Sanyo Katana Screen Replacement, Screen: stap 5, afbeelding 2 van 2
    • Using a Tri-wing Y0 screwdriver, remove the 4.4mm screw.
    • Use fingers to remove the strip from the device.
  6. Sanyo Katana Screen Replacement: stap 6, afbeelding 1 van 3 Sanyo Katana Screen Replacement: stap 6, afbeelding 2 van 3 Sanyo Katana Screen Replacement: stap 6, afbeelding 3 van 3
    • Use a spudger to detach all of the connections to the motherboard in the back of the phone by the screen.
  7. Sanyo Katana Screen Replacement: stap 7, afbeelding 1 van 2 Sanyo Katana Screen Replacement: stap 7, afbeelding 2 van 2
    • Use the flat edge of the spudger to detach the screen from the phone casing.
    • Pull the screen up and away from the case.
Conclusie
Aliceann
49 Reputatie
1 Handleiding geschreven
Clemson, Team 12-1, Benson Spring 2013 Lid van Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 639
