Ga door naar hoofdinhoud
Sanyo Katana Front Case Replacement
Wat je nodig hebt
  1. Sanyo Katana Front Case Replacement, Screen Protector: stap 1, afbeelding 1 van 2 Sanyo Katana Front Case Replacement, Screen Protector: stap 1, afbeelding 2 van 2
    • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  2. Sanyo Katana Front Case Replacement: stap 2, afbeelding 1 van 2 Sanyo Katana Front Case Replacement: stap 2, afbeelding 2 van 2
    • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  3. Sanyo Katana Front Case Replacement: stap 3, afbeelding 1 van 2 Sanyo Katana Front Case Replacement: stap 3, afbeelding 2 van 2
    • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
    • Once free from the adhesive, pull the screen protector away from the phone.
  4. Sanyo Katana Front Case Replacement, Front Case: stap 4, afbeelding 1 van 3 Sanyo Katana Front Case Replacement, Front Case: stap 4, afbeelding 2 van 3 Sanyo Katana Front Case Replacement, Front Case: stap 4, afbeelding 3 van 3
    • Use the spudger to pry off the front case from the left and right sides of the device.
    • Once it has popped off, pull the casing apart with fingers.
Conclusie
StephenYH
20 Reputatie
3 handleidingen geschreven
Clemson, Team 12-1, Benson Spring 2013 Lid van Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 258
