Ga door naar hoofdinhoud
Sanyo Katana Eclipse X Battery Replacement
Wat je nodig hebt
  1. Sanyo Katana Eclipse X Battery Replacement, Back Panel: stap 1, afbeelding 1 van 2 Sanyo Katana Eclipse X Battery Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
    • The phone's battery will now be exposed.
  2. Sanyo Katana Eclipse X Battery Replacement: stap 2, afbeelding 1 van 1
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
  3. Sanyo Katana Eclipse X Battery Replacement, Battery: stap 3, afbeelding 1 van 1
    • Align the copper receptors on the back of your battery so the phone's copper receptors are touching the battery terminals.
    • Refer to photo illustrations.
    • Using your thumb, apply gentle pressure to the battery until it clicks into place.
  4. Sanyo Katana Eclipse X Battery Replacement: stap 4, afbeelding 1 van 1
    • Take the phone’s back casing and set it over the battery.
    • Apply gentle pressure, pushing towards the top of the phone until your hear a click.
Conclusie
Thomas Scaggs
209 Reputatie
2 handleidingen geschreven
University of Maine, Team 1-3, Diaz Fall 2012 Lid van University of Maine, Team 1-3, Diaz Fall 2012
UMAINE-DIAZ-F12S1G3
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 473
