Ga door naar hoofdinhoud
Sansa e260R Scroll Wheel Replacement
Wat je nodig hebt
  1. Sansa e260R Scroll Wheel Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Sansa e260R Scroll Wheel Replacement: stap 2, afbeelding 1 van 1
    • Using a plastic opening tool, lift the metal backing from the front of the device.
  3. Sansa e260R Scroll Wheel Replacement: stap 3, afbeelding 1 van 1
    • Pull the rear panel off of the Sansa e260R.
  4. Sansa e260R Scroll Wheel Replacement, Battery: stap 4, afbeelding 1 van 1
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  5. Sansa e260R Scroll Wheel Replacement, Front Panel: stap 5, afbeelding 1 van 1
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
  6. Sansa e260R Scroll Wheel Replacement: stap 6, afbeelding 1 van 1
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
  7. Sansa e260R Scroll Wheel Replacement: stap 7, afbeelding 1 van 2 Sansa e260R Scroll Wheel Replacement: stap 7, afbeelding 2 van 2
    • Pull the front cover away from the rest of the device.
  8. Sansa e260R Scroll Wheel Replacement, Scroll Wheel: stap 8, afbeelding 1 van 2 Sansa e260R Scroll Wheel Replacement, Scroll Wheel: stap 8, afbeelding 2 van 2
    • Gently pry the bottom of the black button to remove it from the device.
  9. Sansa e260R Scroll Wheel Replacement: stap 9, afbeelding 1 van 2 Sansa e260R Scroll Wheel Replacement: stap 9, afbeelding 2 van 2
    • There are 4 small metal hooks under the white scrolling mechanism.
    • To remove the white scrolling mechanism, remove two of the bottom hooks using a spudger.
  10. Sansa e260R Scroll Wheel Replacement: stap 10, afbeelding 1 van 1
    • Clean the area around the button to remove any dirt or other outside material that would prevent the scroll wheel from moving freely.
Conclusie
6 andere personen hebben deze handleiding voltooid.
JenniferW
194 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-15, Maness Winter 2012 Lid van Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Leden
5 handleidingen geschreven
Één opmerking
Thanks very much for this guide. I used it to expose and clean my Sansa scroll wheel which is now functioning much better.
Lloyd Merriam - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 16
Altijd: 3,232
