Onderdelen
Geen onderdelen nodig.
  1. Before disassembling the device, make sure it is powered off.
    • Before disassembling the device, make sure it is powered off.
    • Remove the four 1.5mm screws on the back of the device.
  2. Using a plastic opening tool, lift the metal backing from the front of the device.
    • Using a plastic opening tool, lift the metal backing from the front of the device.
    • Pull the rear panel off of the Sansa e260R.
    • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
    • Remove the four 1.5mm screws on the inner casing of the device.
    • These screws are very small and hard to extract from the casing. It may be helpful to use a magnetic screwdriver.
    • Flip the device so that the front is facing you.
    • Slide a plastic opening tool between the plastic front cover and the metal back cover of the device.
    • Pull the front cover away from the rest of the device.
Conclusie
Casey Smith
99 Reputatie
3 handleidingen geschreven
Cal Poly, Team 8-15, Maness Winter 2012 Lid van Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Leden
5 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 1,733
