Ga door naar hoofdinhoud
Sanitaire SC684 Roller Brusher and Drive Belt Replacement
  1. Sanitaire SC684 Roller Brusher and Drive Belt Replacement, Roller Brush and Belt: stap 1, afbeelding 1 van 1
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay the vacuum on its back.
  2. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: stap 2, afbeelding 1 van 1
    • Find the metal plate (located directly in the center).
    • Locate the two latches on either side of the metal plate.
    • Detach the latches by pulling them away from metal plate.
  3. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: stap 3, afbeelding 1 van 1
    • Remove the metal plate by pulling it towards you.
  4. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: stap 4, afbeelding 1 van 1
    • Identify the belt and brush roller.
    • The belt is a black ring made of rubber.
    • The brush roller is the long metal tube with bristles attached to it.
  5. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: stap 5, afbeelding 1 van 1
    • Remove the belt from the circular knob by inserting your fingers on either side, gently lifting towards you.
  6. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: stap 6, afbeelding 1 van 2 Sanitaire SC684 Roller Brusher and Drive Belt Replacement: stap 6, afbeelding 2 van 2
    • Pull brush roller out and slip the belt off from the indent in the middle of the roller.
Conclusie
Caycie Pascual
1 Reputatie
4 handleidingen geschreven
Cal Poly, Team 16-58, Forte Fall 2012 Lid van Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 24
Altijd: 2,814
