Gereedschap
Geen gereedschap nodig.
Onderdelen
  1. Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay vacuum on its back
  2. Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Find the bottom metal plate and identify the two latches on either side of the vacuum.
    • Detach the two latches on either side of the vacuum by pulling outwards towards the wheels.
    • Lift off the metal plate by pulling it towards you.
    • Identify the belt and brush roller.
    • The belt is a black circle made of rubber.
    • The brush roller has bristles and is tube shaped.
    • Slide the belt off of the circular knob.
    • Pull brush roller out and detach the belt off the brush roller.
Conclusie
Caycie Pascual
1 Reputatie
5 handleidingen geschreven
Cal Poly, Team 16-58, Forte Fall 2012 Lid van Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 5
Altijd: 831
