Ga door naar hoofdinhoud
Sandisk Sansa m230 Series mp3 player Microphone Replacement
Wat je nodig hebt
  1. Sandisk Sansa m230 Series mp3 player Microphone Replacement, Sandisk Sansa m230 Series mp3 player Teardown: stap 1, afbeelding 1 van 1
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series mp3 player Microphone Replacement: stap 2, afbeelding 1 van 1
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series mp3 player Microphone Replacement: stap 3, afbeelding 1 van 1
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series mp3 player Microphone Replacement: stap 4, afbeelding 1 van 1
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series mp3 player Microphone Replacement: stap 5, afbeelding 1 van 1
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series mp3 player Microphone Replacement: stap 6, afbeelding 1 van 1
    • You now have access to all components found on the inside of the device!
  7. Sandisk Sansa m230 Series mp3 player Microphone Replacement, Microphone: stap 7, afbeelding 1 van 1
    • Locate microphone on motherboard.
  8. Sandisk Sansa m230 Series mp3 player Microphone Replacement: stap 8, afbeelding 1 van 1
    • Find where microphone is connected to motherboard via solder.
  9. Sandisk Sansa m230 Series mp3 player Microphone Replacement: stap 9, afbeelding 1 van 2 Sandisk Sansa m230 Series mp3 player Microphone Replacement: stap 9, afbeelding 2 van 2
    • Use the soldering iron to liquefy the solder connecting the microphone to the motherboard.
  10. Sandisk Sansa m230 Series mp3 player Microphone Replacement: stap 10, afbeelding 1 van 1
    • The solder and soldering iron will be very hot at this time. Do not touch unless wearing protective gloves as you will be burnt.
    • When not in use, be sure to always elevate the hot end of the soldering iron on a metal stand to prevent incidental burns.
  11. Sandisk Sansa m230 Series mp3 player Microphone Replacement: stap 11, afbeelding 1 van 2 Sandisk Sansa m230 Series mp3 player Microphone Replacement: stap 11, afbeelding 2 van 2
    • Remove the faulty microphone as you heat and melt the soldering points.
  12. Sandisk Sansa m230 Series mp3 player Microphone Replacement: stap 12, afbeelding 1 van 1
    • Replace the faulty microphone with a new one in working order.
  13. Sandisk Sansa m230 Series mp3 player Microphone Replacement: stap 13, afbeelding 1 van 2 Sandisk Sansa m230 Series mp3 player Microphone Replacement: stap 13, afbeelding 2 van 2
    • With the new microphone in place, use the soldering iron and solder to create a stable connection between the motherboard and microphone.
    • Give the new solder time to cool and harden.
Conclusie
James Thorne
638 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Lid van UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 496
