Ga door naar hoofdinhoud
Sandisk Sansa m230 Series mp3 player Hold Switch Replacement
Wat je nodig hebt
  1. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement, Sandisk Sansa m230 Series mp3 player Teardown: stap 1, afbeelding 1 van 1
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: stap 2, afbeelding 1 van 1
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: stap 3, afbeelding 1 van 1
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: stap 4, afbeelding 1 van 1
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: stap 5, afbeelding 1 van 1
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: stap 6, afbeelding 1 van 1
    • You now have access to all components found on the inside of the device!
  7. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement, Hold Switch: stap 7, afbeelding 1 van 1
    • Locate the hold switch on the motherboard.
  8. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: stap 8, afbeelding 1 van 1
    • Locate the hold switch connection to the motherboard via soldered connections.
  9. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: stap 9, afbeelding 1 van 1
    • Use the soldering iron to liquefy the solder connecting the hold switch to the motherboard.
  10. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: stap 10, afbeelding 1 van 1
    • The solder and soldering iron will be very hot. Use caution to avoid getting burned.
    • Be sure to always rest the hot end of the soldering iron on a metal stand to prevent accidental burns.
  11. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: stap 11, afbeelding 1 van 1
    • Liquefy the solder on each contact and remove each contact individually.
    • With the contacts removed, lift the switch off the motherboard.
  12. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: stap 12, afbeelding 1 van 1
    • Replace the faulty hold switch with a new one.
  13. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: stap 13, afbeelding 1 van 1
    • There may be some solder in the way of the hold switch's metal contacts. If this occurs simply melt or remove the solder to create room for the contacts.
  14. Sandisk Sansa m230 Series mp3 player Hold Switch Replacement: stap 14, afbeelding 1 van 1
    • With the new hold switch in place, use the soldering iron to solder the contacts between the motherboard and hold switch.
    • Be sure to allow the new solder to cool and harden.
Conclusie
James Thorne
638 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Lid van UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 719
