Ga door naar hoofdinhoud
Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement
Wat je nodig hebt
  1. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement, Sandisk Sansa m230 Series mp3 player Teardown: stap 1, afbeelding 1 van 1
    • Remove the battery compartment cover.
    • Remove the battery.
  2. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Locate and remove the screw next to the battery compartment lid.
  3. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: stap 3, afbeelding 1 van 1
    • Locate the interlocking pegs along the seam of the device's casings.
    • Gently pry the pegs apart one at a time, working your way around the case.
    • Be careful when prying apart the pegs: they are made of plastic and may break.
  4. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: stap 4, afbeelding 1 van 1
    • The battery contact springs may prevent the case from separating.
    • Push the battery contact springs down through the hole in the case.
  5. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: stap 5, afbeelding 1 van 1
    • The casing protecting the USB and headphone jacks must be removed.
    • Locate and gently pry apart the two interlocking clips holding it in place.
    • The outer casings may now be removed and the MP3 player should separate.
  6. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: stap 6, afbeelding 1 van 1
    • You now have access to all components found on the inside of the device!
  7. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement, Headphone Jack: stap 7, afbeelding 1 van 1
    • Locate the headphone jack on the motherboard.
  8. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: stap 8, afbeelding 1 van 1
    • Ensure the hot end of the soldering iron is elevated on a metal stand when not in use to prevent burns.
    • The solder and soldering iron are very hot! Do not touch unless you are wearing appropriate protective gloves.
  9. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: stap 9, afbeelding 1 van 3 Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: stap 9, afbeelding 2 van 3 Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: stap 9, afbeelding 3 van 3
    • Use soldering iron to melt the existing solder at the three headphone jack connections.
  10. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: stap 10, afbeelding 1 van 1
    • Remove the faulty headphone jack from the motherboard.
  11. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: stap 11, afbeelding 1 van 1
    • Align the new headphone jack appropriately on the motherboard for soldering.
  12. Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: stap 12, afbeelding 1 van 3 Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: stap 12, afbeelding 2 van 3 Sandisk Sansa m230 Series MP3 Player Headphone Jack Replacement: stap 12, afbeelding 3 van 3
    • Use the soldering iron and solder to create three stable connections between the motherboard and the headphone jack.
    • Allow the new solder to cool and harden before reassembling the MP3 player.
Conclusie
James Thorne
638 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Lid van UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 1,174
