Wat je nodig hebt
Slide the back cover forward toward the top of the device with your thumb.
Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
CAUTION: Do not fully remove the case cover until the next step has been completed or you may damage the ribbon cable. To be safe, only lift the cover high enough to fit a spudger in the gap.
Using a spudger or flat tool, lift the battery up and away from the board, taking note of its orientation.
Één andere persoon heeft deze handleiding voltooid.
