Ga door naar hoofdinhoud
Samsung WB350F Rear Case Replacement
Wat je nodig hebt
  1. Samsung WB350F Rear Case Replacement, Rear Case: stap 1, afbeelding 1 van 3 Samsung WB350F Rear Case Replacement, Rear Case: stap 1, afbeelding 2 van 3 Samsung WB350F Rear Case Replacement, Rear Case: stap 1, afbeelding 3 van 3
    • Remove the wristlet strap.
    • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
  2. Samsung WB350F Rear Case Replacement: stap 2, afbeelding 1 van 3 Samsung WB350F Rear Case Replacement: stap 2, afbeelding 2 van 3 Samsung WB350F Rear Case Replacement: stap 2, afbeelding 3 van 3
    • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
    • There is one silver screw on the bottom and two black screws on each side.
    • Keep the screws together for an easier re-assembly later.
  3. Samsung WB350F Rear Case Replacement: stap 3, afbeelding 1 van 3 Samsung WB350F Rear Case Replacement: stap 3, afbeelding 2 van 3 Samsung WB350F Rear Case Replacement: stap 3, afbeelding 3 van 3
    • Open the case of the camera using your plastic opening tool.
    • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
    • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
  4. Samsung WB350F Rear Case Replacement: stap 4, afbeelding 1 van 1
    • Remove the plastic casing, exposing the inner workings of the camera.
Conclusie
Zachary Bourgault
101 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 6-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G2
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 684
