Ga door naar hoofdinhoud
Samsung WB350F Battery Replacement
  1. Samsung WB350F Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Samsung WB350F Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Samsung WB350F Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • The first step in replacing the battery is to locate battery compartment. This compartment can be found on the underside of camera.
    • To open this compartment, slide the latch to the left.
  2. Samsung WB350F Battery Replacement: stap 2, afbeelding 1 van 1
    • Depress the battery's retaining clip and remove the old battery.
    • Replace the old battery with a new battery.
Conclusie
Taylor Joubert
273 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 6-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G2
4 Leden
8 handleidingen geschreven
Één opmerking
Does anyone know where to get the battery terminal slide piece. My-Ex wife broke it so that when you slide the part which I don't even know how to do this on purpose!! (at least no without breaking the casing)
danieltbortolini - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 1,850
