Ga door naar hoofdinhoud
Samsung WB2200F Record Button Replacement
Wat je nodig hebt
    1. Samsung WB2200F Record Button Replacement, Face-plate: stap 1, afbeelding 1 van 3 Samsung WB2200F Record Button Replacement, Face-plate: stap 1, afbeelding 2 van 3 Samsung WB2200F Record Button Replacement, Face-plate: stap 1, afbeelding 3 van 3
      • Remove the 6mm screws located on the bottom and sides of the camera using the using the screw driver with the JIS size 000 head.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung WB2200F Record Button Replacement: stap 2, afbeelding 1 van 1
      • Remove the two 6mm screws located underneath the battery cover using the same screw driver with the JIS size 000 head.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung WB2200F Record Button Replacement: stap 3, afbeelding 1 van 1
      • Carefully pry the face-plate away from the body of the camera, starting from the battery compartment. It should come off without too much trouble, although it may require force.
      • Make sure to not damage any of the electronic components of the camera
      Vraag FixBot
      Voeg opmerking toe
    1. Samsung WB2200F Record Button Replacement, Record Button: stap 4, afbeelding 1 van 1
      • Open up the camera by removing the four 6 mm screws, that hold down the metal cover, using the screw driver with the JIS size 000 head.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung WB2200F Record Button Replacement: stap 5, afbeelding 1 van 1
      • Gently lift off the metal cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung WB2200F Record Button Replacement: stap 6, afbeelding 1 van 1
      • Clean out any dust or debris from the button interface.
      • Replace faulty button.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Rudolf Boampong
195 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 5-4, Landers Spring 2016 Lid van UMass Dartmouth, Team 5-4, Landers Spring 2016
UMASSD-LANDERS-S16S5G4
3 Leden
30 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 36
Altijd: 569
