Ga door naar hoofdinhoud
Samsung WB150F Memory Card Replacement
  1. Samsung WB150F Memory Card Replacement, Memory Card: stap 1, afbeelding 1 van 1
    • Flip the camera upside-down so that the compartment with the battery and memory card is facing you.
  2. Samsung WB150F Memory Card Replacement: stap 2, afbeelding 1 van 2 Samsung WB150F Memory Card Replacement: stap 2, afbeelding 2 van 2
    • Using your finger, slide the plastic lock-tab to the left.
    • The compartment should swing open.
  3. Samsung WB150F Memory Card Replacement: stap 3, afbeelding 1 van 1
    • The larger cavity is for the battery.
    • The small thin cavity is where the memory card goes.
    • Press lightly on the memory card to eject it from the camera.
Conclusie
Keith Albergaria
214 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 4-4, Vijaybhaskar Spring 2015 Lid van UMass Dartmouth, Team 4-4, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G4
3 Leden
6 handleidingen geschreven
2Gids Commentaar
Will a micro cd n an adapter fit n the camera?
Maria Elena Will - Antwoord
I was looking for max size compatability. Most folks already know how to remove and install it.
bob kavanaugh - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 34
Altijd: 1,257
