Ga door naar hoofdinhoud
Samsung UBD-KM85C Fan A Replacement
Wat je nodig hebt
  1. Samsung UBD-KM85C Fan A Replacement, Outer Shell: stap 1, afbeelding 1 van 1
    • On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
  2. Samsung UBD-KM85C Fan A Replacement: stap 2, afbeelding 1 van 2 Samsung UBD-KM85C Fan A Replacement: stap 2, afbeelding 2 van 2
    • From the back, lift the case upwards away from the unit then forwards, releasing the prongs on the front.
  3. Samsung UBD-KM85C Fan A Replacement: stap 3, afbeelding 1 van 3 Samsung UBD-KM85C Fan A Replacement: stap 3, afbeelding 2 van 3 Samsung UBD-KM85C Fan A Replacement: stap 3, afbeelding 3 van 3
    • There is one group of wires located towards the front of the case and attached directly to the motherboard and the case. Using two fingers in a pinching motion, release the wire from the clip and disconnect it.
  4. Samsung UBD-KM85C Fan A Replacement: stap 4, afbeelding 1 van 1
    • Remove the cover from the device.
  5. Samsung UBD-KM85C Fan A Replacement, Fan A: stap 5, afbeelding 1 van 1
    • Fan A is located on top of the motherboard and is screwed into a stand by two 6.5mm screws. The stand is also connected to the motherboard.
  6. Samsung UBD-KM85C Fan A Replacement: stap 6, afbeelding 1 van 2 Samsung UBD-KM85C Fan A Replacement: stap 6, afbeelding 2 van 2
    • The two 6.5mm screws holding the fan in place on opposing corners must be removed with a #1 Phillips head screwdriver to change the fan.
  7. Samsung UBD-KM85C Fan A Replacement: stap 7, afbeelding 1 van 3 Samsung UBD-KM85C Fan A Replacement: stap 7, afbeelding 2 van 3 Samsung UBD-KM85C Fan A Replacement: stap 7, afbeelding 3 van 3
    • There is one wire connecting the fan to the motherboard that must be unplugged in order to release it. To unplug, use your fingers to pinch the white clip at the end and gently pull upwards to release.
  8. Samsung UBD-KM85C Fan A Replacement: stap 8, afbeelding 1 van 1
    • The fan can now be lifted from the stand.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
James Edwards
627 Reputatie
5 handleidingen geschreven
Baylor, Team S2-G1, Johnson Spring 2018 Lid van Baylor, Team S2-G1, Johnson Spring 2018
BU-JOHNSON-S18S2G1
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 228
