Inleiding
This guide will help you replace the processor cooling fan for the Samsung UBD-K8500. A faulty cooling fan can lead to an overheating device causing hardware and short circuit problems.
Wat je nodig hebt
Remove the six 10 mm screws from the back of the unit using a Phillips #0 screwdriver.
Carefully detach the cable from the fan to the circuit board by pulling on the cable connecting the fan to the circuit board.
Bijna klaar!
Conclusie
