Ga door naar hoofdinhoud
Samsung UBD-K8500 Power Supply Board Replacement
Wat je nodig hebt
  1. Samsung UBD-K8500 Power Supply Board Replacement, Top Panel: stap 1, afbeelding 1 van 2 Samsung UBD-K8500 Power Supply Board Replacement, Top Panel: stap 1, afbeelding 2 van 2
    • Remove the six 10 mm screws from the back of the unit using a Phillips #0 screwdriver.
  2. Samsung UBD-K8500 Power Supply Board Replacement: stap 2, afbeelding 1 van 2 Samsung UBD-K8500 Power Supply Board Replacement: stap 2, afbeelding 2 van 2
    • Carefully lift up the top panel.
    • There is a cables that must be disconnected before completely removing the panel.
    • Detach the cable connecting the top panel to the motherboard.
    • Take the top off and set it to the side.
  3. Samsung UBD-K8500 Power Supply Board Replacement, Power Supply Board: stap 3, afbeelding 1 van 2 Samsung UBD-K8500 Power Supply Board Replacement, Power Supply Board: stap 3, afbeelding 2 van 2
    • Using your fingers, carefully pinch the clipping part of the two connectors and gently pull them out of their sockets.
  4. Samsung UBD-K8500 Power Supply Board Replacement: stap 4, afbeelding 1 van 2 Samsung UBD-K8500 Power Supply Board Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 7 mm screws from the power supply board using a Phillips #0 screwdriver.
  5. Samsung UBD-K8500 Power Supply Board Replacement: stap 5, afbeelding 1 van 1
    • Gently remove the power supply board.
Conclusie
Ryan Muscove
334 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 7
Altijd: 90
