Ga door naar hoofdinhoud
Samsung U28E510 Motherboard Replacement
Wat je nodig hebt
  1. Samsung U28E510 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 3 Samsung U28E510 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 3 Samsung U28E510 Motherboard Replacement, Motherboard: stap 1, afbeelding 3 van 3
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the cover and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • Lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Motherboard Replacement: stap 2, afbeelding 1 van 2 Samsung U28E510 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Flip the monitor over so that it is facedown.
    • Remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove backing to reveal signal/power board in center.
  3. Samsung U28E510 Motherboard Replacement: stap 3, afbeelding 1 van 2 Samsung U28E510 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Ensure to grip the connection plugs when removing wires to prevent damage to wires.
    • Unplug wires connected to supply (one on the left and one on right).
    • Disconnect the signal ribbon cable.
    • Pull the motherboard shield off—it's adhered in place by tape, so some force may be needed.
  4. Samsung U28E510 Motherboard Replacement: stap 4, afbeelding 1 van 2 Samsung U28E510 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Lay piece upside down.
    • Use a #2 Phillips screwdriver to remove the two screws that secure the motherboard.
    • Lift the motherboard out of the metal shield.
Conclusie
To reassemble your device, follow these instructions in reverse order. Ensure the bezel snaps in place all around monitor.
3 andere personen hebben deze handleiding voltooid.
Melina
154 Reputatie
1 Handleiding geschreven
Cal Poly, Team S11-G1, Banghart Winter 2018 Lid van Cal Poly, Team S11-G1, Banghart Winter 2018
CPSU-BANGHART-W18S11G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 33
Altijd: 1,335
