Ga door naar hoofdinhoud
Samsung TL220 Power Button Replacement
Wat je nodig hebt
    1. Samsung TL220 Power Button Replacement, Power Button: stap 1, afbeelding 1 van 3 Samsung TL220 Power Button Replacement, Power Button: stap 1, afbeelding 2 van 3 Samsung TL220 Power Button Replacement, Power Button: stap 1, afbeelding 3 van 3
      • Check for debris and dust around the power button to make sure it's clean.
      • If dust is absent, then begin with unscrewing the seven outside shell 4 mm Philips screws with the Philips screw driver.
      • Now carefully pry open the back casing with the ifixit plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    2. Samsung TL220 Power Button Replacement: stap 2, afbeelding 1 van 2 Samsung TL220 Power Button Replacement: stap 2, afbeelding 2 van 2
      • Now that you have the back casing off, gently remove the LCD screen from the camera.
      • Next unscrew the three 4 mm Philips screws on the back panel with the same screw driver(See image).
      Vraag FixBot
      Voeg opmerking toe
    3. Samsung TL220 Power Button Replacement: stap 3, afbeelding 1 van 2 Samsung TL220 Power Button Replacement: stap 3, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Unclip the four connecters that hold down the orange copper film strips with the plastic opening tool.
      • Then carefully pull out the three film strips with the ifixit tweezers.
      Vraag FixBot
      Voeg opmerking toe
    4. Samsung TL220 Power Button Replacement: stap 4, afbeelding 1 van 1
      • Remove the 4 mm Philip screw located above the center film strip with the Philips screw driver. This will allow the top frame to come loose to take off.
      Vraag FixBot
      Voeg opmerking toe
    5. Samsung TL220 Power Button Replacement: stap 5, afbeelding 1 van 1
      • Then pull back the black claw located at the bottom right of the camera, to the right with the plastic opening tool. This holds the main plate down.
      Vraag FixBot
      Voeg opmerking toe
    6. Samsung TL220 Power Button Replacement: stap 6, afbeelding 1 van 1
      • Slowly lift with your fingers, the top frame of the camera to get to the power button.
      Vraag FixBot
      Voeg opmerking toe
    7. Samsung TL220 Power Button Replacement: stap 7, afbeelding 1 van 1
      • Replace power button with new one.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
chelsa
358 Reputatie
3 handleidingen geschreven
3 Tech Girls Lid van 3 Tech Girls
Community
2 Leden
48 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 22
Altijd: 585
