Ga door naar hoofdinhoud
Samsung TL220 LCD Screen Replacement
Wat je nodig hebt
  1. Samsung TL220 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 1
    • Begin with unscrewing the seven outer screws on the camera. There is one on each corner and then three at the bottom.
  2. Samsung TL220 LCD Screen Replacement: stap 2, afbeelding 1 van 1
    • Now carefully pry open the back casing with the ifixit plastic opening tool.
  3. Samsung TL220 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • When the back casing is off, gently move the LCD screen to the side.
    • And then remove the three inner screws to remove the inside case.
  4. Samsung TL220 LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Unclip the four connectors that hold down the orange copper film strips.
    • Then carefully pull out the three film strips with the ifixit plastic opening tool.
  5. Samsung TL220 LCD Screen Replacement: stap 5, afbeelding 1 van 2 Samsung TL220 LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Remove the screw located above the center film strip. This holds the top frame in place.
  6. Samsung TL220 LCD Screen Replacement: stap 6, afbeelding 1 van 1
    • Unclip the four connectors to release the film strips.
  7. Samsung TL220 LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Next unclamp the connector to release the film strip and then you can replace your LCD screen.
Conclusie
Lesley
170 Reputatie
1 Handleiding geschreven
3 Tech Girls Lid van 3 Tech Girls
Community
2 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 731
