Ga door naar hoofdinhoud
Samsung TL220 AF Assist Lamp Replacement
Wat je nodig hebt
  1. Samsung TL220 AF Assist Lamp Replacement, Light Bulb: stap 1, afbeelding 1 van 2 Samsung TL220 AF Assist Lamp Replacement, Light Bulb: stap 1, afbeelding 2 van 2
    • Begin with unscrewing the seven outside shell 4 mm Philip screws with the Philips screw driver.
    • Now carefully pry open the back casing with the ifixit plastic opening tool.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung TL220 AF Assist Lamp Replacement: stap 2, afbeelding 1 van 2 Samsung TL220 AF Assist Lamp Replacement: stap 2, afbeelding 2 van 2
    • Now that you have the back casing off, gently remove the LCD screen up and to lay on top of the table to the right.
    • Next unscrew with the same screw driver, the 4 mm Philip screws on the back panel.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung TL220 AF Assist Lamp Replacement: stap 3, afbeelding 1 van 2 Samsung TL220 AF Assist Lamp Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Unclip the four connecters that hold down the orange copper film strips with the plastic opening tool.
    • Then carefully pull out the three film strips with the ifixit tweezers.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung TL220 AF Assist Lamp Replacement: stap 4, afbeelding 1 van 1
    • Remove the 4 mm Philip screws located above the center film strip with the Philip screw driver. This will allow the top frame to come loose to take off.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung TL220 AF Assist Lamp Replacement: stap 5, afbeelding 1 van 1
    • Then pull the black claw located at the bottom right of the camera, to the right with the plastic opening tool. This holds the main plate down.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung TL220 AF Assist Lamp Replacement: stap 6, afbeelding 1 van 1
    • Slowly lift with your fingers, the top frame of the camera up, disconnecting it from the main piece.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung TL220 AF Assist Lamp Replacement: stap 7, afbeelding 1 van 1
    • This piece disconnected exposes the light bulb that you can change out at this point in the guide.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
chelsa
358 Reputatie
3 handleidingen geschreven
3 Tech Girls Lid van 3 Tech Girls
Community
2 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 25
Altijd: 437
