Ga door naar hoofdinhoud
Samsung Sway Rear Cover Replacement
Wat je nodig hebt
  1. Samsung Sway Rear Cover Replacement, Rear cover: stap 1, afbeelding 1 van 1
    • Turn over the phone and make sure the slider is closed.
  2. Samsung Sway Rear Cover Replacement: stap 2, afbeelding 1 van 2 Samsung Sway Rear Cover Replacement: stap 2, afbeelding 2 van 2
    • Using your thumb(s) slide the battery cover up to remove it.
  3. Samsung Sway Rear Cover Replacement: stap 3, afbeelding 1 van 2 Samsung Sway Rear Cover Replacement: stap 3, afbeelding 2 van 2
    • Using your finger, grasp the corner on either side of the battery and pull up.
  4. Samsung Sway Rear Cover Replacement: stap 4, afbeelding 1 van 1
    • Unscrew the four corner .4cm Phillips head screws and the two middle .3 cm Phillips head screws.
  5. Samsung Sway Rear Cover Replacement: stap 5, afbeelding 1 van 1
    • Gently insert a pair of tweezers under the Samsung logo on the bottom of the phone. Then unscrew the two .4 cm Phillips head screws underneath.
  6. Samsung Sway Rear Cover Replacement: stap 6, afbeelding 1 van 1
    • Gently insert the plastic opening tool into the seam where the battery was located. Work the opening tool around until the back cover comes off. Make sure to be careful of the side buttons that pop off.
Conclusie
Chris Rush
306 Reputatie
3 handleidingen geschreven
WRI115, Team 1-2, Ruszkiewicz Spring 2013 Lid van WRI115, Team 1-2, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 260
