1. Turn the Samsung Sway over to access the rear cover.
    • Turn the Samsung Sway over to access the rear cover.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. Using your thumb(s) slide the cover away from the device, and then place the cover to the side. Using your thumb(s) slide the cover away from the device, and then place the cover to the side.
    • Using your thumb(s) slide the cover away from the device, and then place the cover to the side.
  4. Grip the corner of the battery on either the left or right side with your fingers and lift it up to remove it.
    • Grip the corner of the battery on either the left or right side with your fingers and lift it up to remove it.
Conclusie
To reassemble your device, insert new battery and slide the back cover back on to the device
Chris Rush
301 Reputatie
3 handleidingen geschreven
WRI115, Team 1-2, Ruszkiewicz Spring 2013 Lid van WRI115, Team 1-2, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G2
4 Leden
6 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 186
