Ga door naar hoofdinhoud
Samsung Spex SCH-R210 Battery Replacement
  1. Samsung Spex SCH-R210 Battery Replacement, Back Cover: stap 1, afbeelding 1 van 3 Samsung Spex SCH-R210 Battery Replacement, Back Cover: stap 1, afbeelding 2 van 3 Samsung Spex SCH-R210 Battery Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
  2. Samsung Spex SCH-R210 Battery Replacement, Battery: stap 2, afbeelding 1 van 1
    • Locate the access notch at the end of the battery compartment.
  3. Samsung Spex SCH-R210 Battery Replacement: stap 3, afbeelding 1 van 1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
Conclusie
Austin
201 Reputatie
2 handleidingen geschreven
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Lid van WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 286
