Ga door naar hoofdinhoud
Samsung Solstice Battery Replacement
Wat je nodig hebt
  1. Samsung Solstice Battery Replacement, Removing the back cover: stap 1, afbeelding 1 van 3 Samsung Solstice Battery Replacement, Removing the back cover: stap 1, afbeelding 2 van 3 Samsung Solstice Battery Replacement, Removing the back cover: stap 1, afbeelding 3 van 3
    • Gently slide the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
    • Set the cover off to the side once you have removed it.
  2. Samsung Solstice Battery Replacement, Removing the battery: stap 2, afbeelding 1 van 3 Samsung Solstice Battery Replacement, Removing the battery: stap 2, afbeelding 2 van 3 Samsung Solstice Battery Replacement, Removing the battery: stap 2, afbeelding 3 van 3
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool in between the rear end of the battery and the plastic frame.
    • Pry the battery up out of its recess and away from the phone.
Conclusie
Colton Glyder
301 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 345
