Inleiding
If your Samsung Series 9 NP900X4B-A02 laptop is not producing sound or it is producing distorted sound, use this guide to replace the internal speakers. The speakers output audio from the laptop, and faulty speakers will either not produce audio or produce audio that is distorted.
Before using this guide, ensure that your audio problems are not caused by a software issue, and ensure that the laptop is powered off and disconnected from the power source.
Wat je nodig hebt
Remove the ten screws along the base using a Phillips #000.
Use a Plastic Opening Tool to pry open the base .
Unplug the left speaker's cable from the motherboard.
Lift up and remove the left speaker.
