Ga door naar hoofdinhoud
Samsung Series 9 NP900X4B-A02 I/O PCB Replacement
Wat je nodig hebt
  1. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Battery: stap 1, afbeelding 1 van 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Battery: stap 1, afbeelding 2 van 2
    • Ensure computer is unplugged and powered down before continuing.
    • Remove the ten screws along the base using a Phillips #000.
    • Use a Plastic Opening Tool to pry open the base .
  2. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 2, afbeelding 1 van 1
    • The battery is now unobstructed from your view.
    • Before removing the battery, use the plastic opening tool to detach the ribbon wire cable that connects the battery to the motherboard.
  3. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 3, afbeelding 1 van 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 3, afbeelding 2 van 2
    • Use the Phillips #000 screwdriver to remove six screws that are holding the battery in place.
  4. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 4, afbeelding 1 van 1
    • Lift and pull out the battery.
  5. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: stap 5, afbeelding 1 van 3 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: stap 5, afbeelding 2 van 3 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Speaker: stap 5, afbeelding 3 van 3
    • Unplug the left speaker's cable from the motherboard.
    • Lift up and remove the left speaker.
  6. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 6, afbeelding 1 van 3 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 6, afbeelding 2 van 3 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 6, afbeelding 3 van 3
    • Unplug the right speaker's cable from the motherboard.
    • Lift up and remove the right speaker.
  7. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Fan: stap 7, afbeelding 1 van 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, Fan: stap 7, afbeelding 2 van 2
    • Next locate the two Phillips #0 2.5mm screws on both the top right and bottom left corner of the fan.
  8. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 8, afbeelding 1 van 1
    • After locating the screws, using the Phillips #0 screwdriver, remove the screws from the fan.
  9. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 9, afbeelding 1 van 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 9, afbeelding 2 van 2
    • Use the plastic opening tool to remove the cable connector from its housing which is just to the right of the fan.
  10. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 10, afbeelding 1 van 1
    • Once the cable has been removed from its housing you are free to remove the fan from the laptop.
    • You can either clean the fan with a computer duster or other cleaner, or replace it with a new one.
  11. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement, I/O PCB: stap 11, afbeelding 1 van 1
    • Remove the five 2.5 mm Phillips #00 screws securing the I/O PCB.
  12. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 12, afbeelding 1 van 1
    • Lift and pull the SSD from the board.
  13. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 13, afbeelding 1 van 1
    • Disconnect the black press fit connector by gently lifting up.
  14. Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 14, afbeelding 1 van 2 Samsung Series 9 NP900X4B-A02 I/O PCB Replacement: stap 14, afbeelding 2 van 2
    • The I/O PCB is adhered to the frame.
    • Use an opening tool or spudger to carefully pry up the right edge of the I/O PCB.
    • Pull the board to the right and remove it.
    • You may need to wiggle the board to loosen the adhesive holding it in place.
Conclusie
Brady Hildreth
382 Reputatie
3 handleidingen geschreven
IUPUI, Team S1-G4, Henning Fall 2019 Lid van IUPUI, Team S1-G4, Henning Fall 2019
IUPUI-HENNING-F19S1G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 289
