Ga door naar hoofdinhoud
Samsung Series 9 NP900X3A Memory Card Replacement
Wat je nodig hebt
  1. Samsung Series 9 NP900X3A Memory Card Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
    • Screws securing the back panel underneath the adhesive will be exposed.
    • Removing the rubber feet will weaken the adhesive making reassembly difficult. Apply new adhesive if you choose to place the rubber feet back on to the device.
  2. Samsung Series 9 NP900X3A Memory Card Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
    • Keep track of the screws and their placement on the laptop. This will help make reassembly easier and more organized.
  3. Samsung Series 9 NP900X3A Memory Card Replacement: stap 3, afbeelding 1 van 3 Samsung Series 9 NP900X3A Memory Card Replacement: stap 3, afbeelding 2 van 3 Samsung Series 9 NP900X3A Memory Card Replacement: stap 3, afbeelding 3 van 3
    • Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
    • Use both hands when removing the back case cover. Too much force will bend the cover making it difficult to reassemble.
  4. Samsung Series 9 NP900X3A Memory Card Replacement, USB & Headphone I/O Board: stap 4, afbeelding 1 van 1
    • Locate the AUX and USB port on the left side of the laptop.
  5. Samsung Series 9 NP900X3A Memory Card Replacement: stap 5, afbeelding 1 van 1
    • Remove the one 0.1mm screw using a Phillips #0 Screwdriver from the laptop.
    • Keep track of the 0.1mm screws for reassembly later.
  6. Samsung Series 9 NP900X3A Memory Card Replacement: stap 6, afbeelding 1 van 1
    • Use a plastic prying tool to remove the top connector of the port from the motherboard.
    • This should come out very easily and allow access to the Memory card.
  7. Samsung Series 9 NP900X3A Memory Card Replacement: stap 7, afbeelding 1 van 1
    • Remove the second connector from the motherboard using the prying tool.
    • This should come out very easily, and allow access to the Memory card.
  8. Samsung Series 9 NP900X3A Memory Card Replacement: stap 8, afbeelding 1 van 2 Samsung Series 9 NP900X3A Memory Card Replacement: stap 8, afbeelding 2 van 2
    • Find an opening on the side of the port and pry the USB and AUX port out of the laptop with the prying tool.
  9. Samsung Series 9 NP900X3A Memory Card Replacement: stap 9, afbeelding 1 van 1
    • Remove and place the port outside of the laptop. You are free to install your new USB and HDMI ports.
  10. Samsung Series 9 NP900X3A Memory Card Replacement, Memory Card: stap 10, afbeelding 1 van 1
    • Using your Phillips #0 Screwdriver, unscrew the 0.1mm screws securing the memory card in place at the top.
    • Remember to keep track of the screws for reassembly.
  11. Samsung Series 9 NP900X3A Memory Card Replacement: stap 11, afbeelding 1 van 3 Samsung Series 9 NP900X3A Memory Card Replacement: stap 11, afbeelding 2 van 3 Samsung Series 9 NP900X3A Memory Card Replacement: stap 11, afbeelding 3 van 3
    • After removing the screws, your card should angle upward making for an easier removal.
    • Using both hands, gently lift the card out of its socket in the direction away from yourself.
    • Use caution when removing the card, bending the pins will damage the socket and your ability to reuse the memory card if you plan to.
  12. Samsung Series 9 NP900X3A Memory Card Replacement: stap 12, afbeelding 1 van 1
    • Replace the the card with a new compatible memory card.
    • To install your new memory card, follow these steps in reverse order.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 1,184
