Inleiding
If your computer is no longer holding a charge or is dying quickly without a charger, then you should replace the battery. This guide will help you replace the battery.
Wat je nodig hebt
Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
Remove the last three remaining 0.1mm screws attached to the battery.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
Where’s the best place to purchase an original replacement battery for this model: NP900X3A
email:
Best Email: Only related to this product SAMSUNG Model: NP900X3A.
cotodecaza@gmail.com
Thank You,
Giancarlo
