Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
As a laptop gets older, the keys may begin to stick and not function correctly. This guide will show how to clean underneath the keys and how to replace them if necessary.
  1. To take off the keys, simply use the plastic opening tool or a similar pointed object to take off the desired key(s). To take off the keys, simply use the plastic opening tool or a similar pointed object to take off the desired key(s).
    • To take off the keys, simply use the plastic opening tool or a similar pointed object to take off the desired key(s).
  2. To clean underneath the keys, canned air works well. To clean underneath the keys, canned air works well.
    • To clean underneath the keys, canned air works well.
  3. Place the new key into its location. Press until it "clicks". Make sure the new key is in the proper place on the QWERTY keyboard.
    • Place the new key into its location. Press until it "clicks".
    • Make sure the new key is in the proper place on the QWERTY keyboard.
Eindstreep
Timothy
1.452 Reputatie
5 handleidingen geschreven
USF Tampa, Team 16-3, Watkins Winter 2015 Lid van USF Tampa, Team 16-3, Watkins Winter 2015
USFT-WATKINS-W15S16G3
4 Leden
Één commentaar
how can i get the cover parts and hinge for this laptop mine needs them and im looking for them..are you selling?
alkane - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 64
Altijd: 6,194
