Ga door naar hoofdinhoud
Samsung Series 5 UltraTouch Battery Replacement
Wat je nodig hebt
  1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: stap 1, afbeelding 1 van 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: stap 1, afbeelding 2 van 2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
    The user manual recommends, before removing the cover:
    "Insert an object, such as a paper clip, into the Emergency Hole at the bottom of the computer to cut the battery power. If the Power button does not work anymore, that means you successfully shut the power off."
    This seems to make sure power is completely off or something. The hole can be seen in the picture; it is located in the center, very near where the screwdriver is.
    Pachi - Antwoord
  2. Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: stap 2, afbeelding 1 van 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: stap 2, afbeelding 2 van 2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: stap 3, afbeelding 1 van 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: stap 3, afbeelding 2 van 2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 UltraTouch Battery Replacement: stap 4, afbeelding 1 van 2 Samsung Series 5 UltraTouch Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 UltraTouch Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 UltraTouch Battery Replacement, Remove the Battery: stap 6, afbeelding 1 van 1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 UltraTouch Battery Replacement: stap 7, afbeelding 1 van 1
    • Remove the battery from the laptop.
Conclusie
14 andere personen hebben deze handleiding voltooid.
Timothy
1.579 Reputatie
5 handleidingen geschreven
USF Tampa, Team 16-3, Watkins Winter 2015 Lid van USF Tampa, Team 16-3, Watkins Winter 2015
USFT-WATKINS-W15S16G3
4 Leden
2 opmerkingen
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
Chris - Antwoord
If you have a computer connected to a power supply that will still allow it to work.
Ruben Guardado -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 47
Altijd: 26,766
