Ga door naar hoofdinhoud
Samsung Series 5 UltraTouch Battery Replacement
Wat je nodig hebt
  1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: stap 1, afbeelding 1 van 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: stap 1, afbeelding 2 van 2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: stap 2, afbeelding 1 van 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: stap 2, afbeelding 2 van 2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: stap 3, afbeelding 1 van 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: stap 3, afbeelding 2 van 2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 UltraTouch Battery Replacement: stap 4, afbeelding 1 van 2 Samsung Series 5 UltraTouch Battery Replacement: stap 4, afbeelding 2 van 2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 UltraTouch Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 UltraTouch Battery Replacement, Remove the Battery: stap 6, afbeelding 1 van 1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 UltraTouch Battery Replacement: stap 7, afbeelding 1 van 1
    • Remove the battery from the laptop.
Conclusie
14 andere personen hebben deze handleiding voltooid.
Timothy
1.579 Reputatie
5 handleidingen geschreven
USF Tampa, Team 16-3, Watkins Winter 2015 Lid van USF Tampa, Team 16-3, Watkins Winter 2015
USFT-WATKINS-W15S16G3
4 Leden
2 opmerkingen
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
Chris - Antwoord
If you have a computer connected to a power supply that will still allow it to work.
Ruben Guardado -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 46
Altijd: 26,770
