Inleiding
Outline what you are going to teach someone how to do.
  1. Make sure your Chromebook is powered off before you begin.
    • Make sure your Chromebook is powered off before you begin.
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel. The easiest way to do this is to use your fingernails to pick them out.
    • Remove all the seven screws in the bottom panel.
  2. Loosen the back cover panel by using the flathead screwdriver or the spudger.
    • Loosen the back cover panel by using the flathead screwdriver or the spudger.
    • Once you work your way around, you can remove the panel.
    • Remove the single Phillip screw
    • Disconnect the WWAN antennas from the I/O board
    • Remove the WWAN board from the motherboard.
Conclusie
Helder Avelino
849 Reputatie
5 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 548
