Ga door naar hoofdinhoud
Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement
Wat je nodig hebt
  1. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the computer upside down, with the battery pack facing away from you.
  2. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: stap 2, afbeelding 1 van 2 Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery by pushing out the locks on either end then pushing the battery away from you.
  3. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement, Panel: stap 3, afbeelding 1 van 1
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw on the ODD/HDD Memory panel.
  4. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: stap 4, afbeelding 1 van 2 Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: stap 4, afbeelding 2 van 2
    • Pull the panel towards you to release it, then lift it off the computer.
  5. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: stap 5, afbeelding 1 van 1
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw next to the label “ODD."
    • Remove the three 4.5mm screws from around the memory drive nest.
  6. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: stap 6, afbeelding 1 van 1
    • Using the J1 Japanese Industrial Standard screwdriver, remove the thirteen 9.5mm screws from the panel that cover the bottom of the computer.
  7. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: stap 7, afbeelding 1 van 3 Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: stap 7, afbeelding 2 van 3 Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement: stap 7, afbeelding 3 van 3
    • Begin removing the computer casing by prying beside the disk drive with the iFixit opening tool and the spudger, working counterclockwise.
    • Lift the panel from the computer.
  8. Samsung Series 3 NP300E5A-A02UB Disc Drive Replacement, Disc Drive: stap 8, afbeelding 1 van 1
    • Remove the disc drive by pulling it towards the outside of the computer.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 14
Altijd: 382
