Ga door naar hoofdinhoud
Samsung ST700 Battery Replacement
Wat je nodig hebt
  1. Samsung ST700 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • The battery is located on the bottom of the camera underneath a latch door
    • To open the latched door, move the latch (circled in the picture) toward the center of the camera, and the door should pop open.
  2. Samsung ST700 Battery Replacement: stap 2, afbeelding 1 van 1
    • When the bottom componets are exposed, the battery is held by a blue latch. (Blue latch is circled in the picture)
    • Push the blue latch latch to relase the battery from its slot. It should be pushed out.
    • Remove the battery.
    • Move the blue latch to put in the new battery.
    • Make sure that the battery is going in the correct way. The three golden slits should be matching up with three golden prongs on the bottom of the battery holder.
    • Close the latch door over the components and move the latch toward the side of the camera. Trying turning on the camera.
Conclusie
Tanner Studley
125 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 6-4, Bhusal Spring 2016 Lid van UMass Dartmouth, Team 6-4, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G4
3 Leden
1 handleiding geschreven
Één opmerking
my baterry inflated with air and now is stuck in the slot, what should i do?
Denix 54 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 392
