Ga door naar hoofdinhoud
Samsung ST150F Rear Panel Control Board Replacement
Wat je nodig hebt
  1. Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: stap 1, afbeelding 1 van 3 Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: stap 1, afbeelding 2 van 3 Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: stap 1, afbeelding 3 van 3
    • Remove these screws from the camera using a phillips head screwdriver.
  2. Samsung ST150F Rear Panel Control Board Replacement: stap 2, afbeelding 1 van 1
    • Lay the camera down on the table and remove the metal shell from the front.
  3. Samsung ST150F Rear Panel Control Board Replacement: stap 3, afbeelding 1 van 1
    • Wedge a spudger/flathead screwdriver inside of the shell where the screws were to pry the shell off of the back.
  4. Samsung ST150F Rear Panel Control Board Replacement: stap 4, afbeelding 1 van 1
    • Remove the shell the from the back of the camera.
  5. Samsung ST150F Rear Panel Control Board Replacement, Rear Panel Control Board: stap 5, afbeelding 1 van 1
    • Remove the Phillips head screw from the rear panel control board to reveal the LCD's connection to the motherboard.
  6. Samsung ST150F Rear Panel Control Board Replacement: stap 6, afbeelding 1 van 3 Samsung ST150F Rear Panel Control Board Replacement: stap 6, afbeelding 2 van 3 Samsung ST150F Rear Panel Control Board Replacement: stap 6, afbeelding 3 van 3
    • Remove the Phillips head screws from the metal back plate.
  7. Samsung ST150F Rear Panel Control Board Replacement: stap 7, afbeelding 1 van 1
    • Use the spudger to life the tab on the side of the metal plate.
  8. Samsung ST150F Rear Panel Control Board Replacement: stap 8, afbeelding 1 van 2 Samsung ST150F Rear Panel Control Board Replacement: stap 8, afbeelding 2 van 2
    • Pull gently on the control panel to remove it from the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Matthew Eaton
107 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 2-1, Shastany Spring 2015 Lid van UMass Dartmouth, Team 2-1, Shastany Spring 2015
UMASSD-SHASTANY-S15S2G1
4 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 48
Altijd: 994
