Ga door naar hoofdinhoud
Samsung SPH-A500 Speaker Replacement
Wat je nodig hebt
  1. Samsung SPH-A500 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Samsung SPH-A500 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Using an Ipod opening tool or your finger nails, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Samsung SPH-A500 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Samsung SPH-A500 Speaker Replacement: stap 4, afbeelding 1 van 1
    • The speaker is covered with silver tape on the bottom of the logic board.
  5. Samsung SPH-A500 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove the silver tape that is covering the speaker.
  6. Samsung SPH-A500 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Remove the speaker.
    • Note: In order to completely remove the speaker you must disconnect the wires, which will require a soldering iron to reattach the new speaker.
  7. Samsung SPH-A500 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Attach the new speaker using a soldering iron.
    • Put the speaker back to it's original position and place the silver tape over it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nick Dominikovic
139 Reputatie
4 handleidingen geschreven
Cal Poly, Team 18-100, Johann Spring 2010 Lid van Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,323
