Ga door naar hoofdinhoud
Samsung SPH-A500 Keypad Replacement
Wat je nodig hebt
  1. Samsung SPH-A500 Keypad Replacement, Keypad: stap 1, afbeelding 1 van 1
    • Turn phone over
    • Push the gray tab above the battery forward to remove the battery.
  2. Samsung SPH-A500 Keypad Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
  3. Samsung SPH-A500 Keypad Replacement: stap 3, afbeelding 1 van 1
    • Remove all four screws using a small Philips screwdriver.
    • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
  4. Samsung SPH-A500 Keypad Replacement: stap 4, afbeelding 1 van 1
    • Remove back cover by carefully prying it open.
    • Note: Some force may be required.
  5. Samsung SPH-A500 Keypad Replacement: stap 5, afbeelding 1 van 1
    • Pull the side tabs outward while simultaneously lifting up the circuit board.
  6. Samsung SPH-A500 Keypad Replacement: stap 6, afbeelding 1 van 1
    • Lift circuit board from the bottom of the phone.
    • WARNING: DO NOT completely remove circuit board from the phone, since it is still attached at the top of the phone.
  7. Samsung SPH-A500 Keypad Replacement: stap 7, afbeelding 1 van 1
    • Flip the circuit board around the top of the phone.
    • Lift the rubber keypad off.
  8. Samsung SPH-A500 Keypad Replacement: stap 8, afbeelding 1 van 1
    • Replace the keypad.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nick Dominikovic
139 Reputatie
4 handleidingen geschreven
Cal Poly, Team 18-100, Johann Spring 2010 Lid van Cal Poly, Team 18-100, Johann Spring 2010
CPSU-JOHANN-S10S18G100
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 1,800
