Ga door naar hoofdinhoud
Samsung SGH-X495 Speakers Replacement
Wat je nodig hebt
  1. Samsung SGH-X495 Speakers Replacement, Face Plate: stap 1, afbeelding 1 van 1
    • First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
  2. Samsung SGH-X495 Speakers Replacement: stap 2, afbeelding 1 van 1
    • Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
  3. Samsung SGH-X495 Speakers Replacement: stap 3, afbeelding 1 van 2 Samsung SGH-X495 Speakers Replacement: stap 3, afbeelding 2 van 2
    • As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
    • Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
    • Note: The bottom 2 are the most challenging to remove.
    • Note: When reassembling start with the bottom two tabs.
  4. Samsung SGH-X495 Speakers Replacement: stap 4, afbeelding 1 van 2 Samsung SGH-X495 Speakers Replacement: stap 4, afbeelding 2 van 2
    • Continue down each side toward the bottom with your pry tool.
    • Note: It may help to use multiple pry tools to help hold it open.
    • Second photo: location of the tabs.
  5. Samsung SGH-X495 Speakers Replacement: stap 5, afbeelding 1 van 2 Samsung SGH-X495 Speakers Replacement: stap 5, afbeelding 2 van 2
    • With 8 tabs released, the face plate is nearly free.
    • With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
    • Note: A strip of double sided tape holds the faceplate, so expect some resistance
  6. Samsung SGH-X495 Speakers Replacement, Speakers: stap 6, afbeelding 1 van 2 Samsung SGH-X495 Speakers Replacement, Speakers: stap 6, afbeelding 2 van 2
    • Remove the 2 speakers by gently prying them up.
    • The speakers are attached with double sided tape.
  7. Samsung SGH-X495 Speakers Replacement: stap 7, afbeelding 1 van 1
    • With the speakers free from the phones body the screen is loose as well.
    • The desired solder joint can be accessed to attach a new speaker.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Matthew Hove
1.031 Reputatie
10 handleidingen geschreven
Cal Poly, Team 3-40, Regan Winter 2011 Lid van Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 1,777
