Ga door naar hoofdinhoud
Samsung SGH-X495 Motherboard Replacement
Wat je nodig hebt
  1. Samsung SGH-X495 Motherboard Replacement, Backplate: stap 1, afbeelding 1 van 1
    • Remove the 4 (4.7mm) philips head screws.
  2. Samsung SGH-X495 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Unplug the rubber charger outlet cover.
  3. Samsung SGH-X495 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Unplug the rubber headset jack cover.
  4. Samsung SGH-X495 Motherboard Replacement: stap 4, afbeelding 1 van 2 Samsung SGH-X495 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Begin by inserting the pry tool near the charger jack.
    • There are 4 tabs to release.
    • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
    • Loosen the 2 side tabs before moving on to the top two.
    • See the second photo to see location of the tabs.
    • Be careful of the ribbon wires shown in second photo.
  5. Samsung SGH-X495 Motherboard Replacement: stap 5, afbeelding 1 van 2 Samsung SGH-X495 Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
    • Hold the phone with the left hand as shown
    • Wiggle the white backplate from side to side while pulling down with the right hand.
  6. Samsung SGH-X495 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Remove the ribbon wires connecting to the screen using the pry tool.
  7. Samsung SGH-X495 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • 2 tabs hold the motherboard in place.
    • Release the labeled tabs with the pry tool from the location shown.
  8. Samsung SGH-X495 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Separate the motherboard from the phone.
Conclusie
Matthew Hove
1.031 Reputatie
10 handleidingen geschreven
Cal Poly, Team 3-40, Regan Winter 2011 Lid van Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 13
Altijd: 1,858
